- Wanted : Camshaft for a C90 16F
- Grover Anderson
15 Mar 2016 09:59 #1
by Grover Anderson
Replied by Grover Anderson on topic Wanted : Camshaft for a C90 16F
Robert
There is a camshaft for a 90 HP engine on e-bay($399)---643067. It was overhauled by Aircraft specialties Service in Tulsa OK. If this is not the one for your Alon engine,call this shop;
918-836-6872
I think that the camshaft for the 90 HP Alon is the same one for a 100HP c. 0200?
Grover Anderson
918-836-6872
Grover Anderson
- Robert Tompkins
13 Mar 2016 11:14 #2
by Robert Tompkins
Replied by Robert Tompkins on topic Wanted : Camshaft for a C90 16F
Dear Grover,
I am sorry that I cannot help you, as I was unable to help myself.
Searching high and low, I was unable to find the correct camshaft.
My only alternative is to try and have my camshaft overhauled and
assuming this can be done, reinstall it. I am afraid that this is probably
your only course of action.
By the way, most likely you will have had problems with the tappets. At least
these are easy to find and replace.
Good luck
Good luck
- Grover Anderson
12 Mar 2016 17:10 #3
by Grover Anderson
Robert'
I am looking at buying a 1966 Alon A2. There is a question about the camshaft making metal in the filter at annual. What happened to your camshaft and how many hours did the engine have on it. How did you know you had a bad camshaft?
Grover Anderson
Grover Anderson
- Super User
11 Feb 2016 13:02 #4
by Super User
Replied by Super User on topic Wanted : Camshaft for a C90 16F
Maybe you can send it to a repair shop? I understand you're more likely to find hen's teeth.
And, a repair is likely to cost less. They'll spatter material on it and grind it to new specs.
josef
josef
- Robert Tompkins
11 Feb 2016 12:02 #5
by Robert Tompkins
Wanted : Camshaft for a C90 16F was created by Robert Tompkins
Dear All,
I need to replace my camshaft on my Alon A2A which has a C90 16F motor. The part number I am looking for is 531146. Does anyone happen to have one of these lying around?
Many thanks
Robert Tompkins
N5478F
Many thanks
Robert Tompkins
N5478F
