- proper air pressure for ercoupe 415-C tires ?
- Steve Westlund
08 Sep 2019 20:40 #1
by Steve Westlund
Replied by Steve Westlund on topic proper air pressure for ercoupe 415-C tires ?
My 415-C service manual calls for 20 lbs air pressure for the nose tire and 17 lbs for the mains. That's the air pressure I've been using and it's worked well.
Steve
Steve
12 Jun 2019 12:00 #2
Replied by Larry Snyder on topic proper air pressure for ercoupe 415-C tires ?
Try 20 PSI in the main gear tires and 17-18 PSI in the nose tire. I’ve been using that for years and it gives a decent roll with a minimum of shimmy.
- David Jones
12 Jun 2019 11:37 #3
by David Jones
Replied by David Jones on topic proper air pressure for ercoupe 415-C tires ?
Bill,
My guess is that it depends on the number of ply's your tire has. Desser Tire and Rubber has a chart that prescribes the psi for specific tire types. I know this because I am in the middle of replacing the nose and both mains due to dry-rot!
Hope this gives you some assistance.
David Jones
N3589H
David Jones
N3589H
- William James
25 Mar 2019 10:51 #4
by William James
proper air pressure for ercoupe 415-C tires ? was created by William James
Can someone give me the proper air pressure for Ercoupe 415-C tires . have had several different answers
Bill James
Bill James
