- fuel pump indicator flicker
13 Nov 2026 23:24 #1
Replied by Matt Gunsch on topic fuel pump indicator flicker
the light is probably operated by a pressure switch, either the switch is going, or the electric pump, only way to figure which is to put a pressure guage in line and see what is going on
- Jim Kadel
05 Sep 2026 13:52 #2
by Jim Kadel
fuel pump indicator flicker was created by Jim Kadel
My electric fuel pump indicator light has a constant flicker. Yes, it will glow bright red if my wing tanks are empty and it is pumping air. Is the flicker indicative of a weak electric pump? Jim K. 1946 415-D 100 hp. engine
