Replacement fuel pressure switch for M4007-4, o-200 crankshaft electric pump
  • Ken Thompson
04 Mar 2020 20:46 #1 by Ken Thompson
Dale, I know some C85s have had electric fuel pumps installed. I don’t think it very common but certainly not unheard of.
  • Dale Huffman
04 Mar 2020 20:31 #2 by Dale Huffman
Ken,
We just recently purchased aircraft and logs indicate C85 engine with o200 crank. Not o200 engine. Has correct log entry for electric pump. Still learning.
  • Ken Thompson
01 Mar 2020 13:39 #3 by Ken Thompson
Hey Dale. Welcome to our world. Please clarify something for me. You say you have the 0-200 crank conversion. Do you mean that you have an 0-200 engine? Or a C-85 with the 0-200 STC that uses the crank, rods, and pistons of the 0-200?
The full 0-200 engine swap requires an electric fuel pump. The STC that installs just the crank, rods, and pistons does NOT require an electric fuel pump.
  • Lawson Laslo
30 Jan 2020 21:51 #4 by Lawson Laslo
If you could send me a email to This email address is being protected from spambots. You need JavaScript enabled to view it. I can send you a file with the installation instructions for o200 which does talk about fuel pump
  • Lawson Laslo
30 Jan 2020 21:39 #5 by Lawson Laslo
this is all I can find in my book
Photos are below
Hope this helps
Let me know if you need anything else
  • Dale Huffman
30 Jan 2020 20:26 #6 by Dale Huffman
Is there any chance you would have a schematic or sketch for the fuel pump installation. Just purchased ERCOUPE and now sorting out 74 years of “improvements”. It would be greatly appreciated.
