How to change GW from 1400 to 1450 on Forney F1?
  • Brian Hausknecht
13 Aug 2023 22:46 - 13 Aug 2023 22:46 #1 by Brian Hausknecht
Replied by Brian Hausknecht on topic How to change GW from 1400 to 1450 on Forney F1?
The Airworthiness Specs file 787 (in the files on the EOC site) gives the modifications needed to convert an F1 to a F1A with the 1450# GW. The info is in Note 5 on the last page of the specifications. The trick will be to get and install these parts. Since they are part of the Airworthiness specs, an A&P will have confirm whether paperwork other than a logbook entry is needed to install the parts and increase GW (the latter of course will require a new W&B calculation and form.)
Last edit: 13 Aug 2023 22:46 by Brian Hausknecht.
03 Dec 2022 02:45 #2 by Warren Hampton
Replied by Warren Hampton on topic How to change GW from 1400 to 1450 on Forney F1?
I just sent Matt Gunsch the paperwork Forney did to up to 1450 lbs. for the FAA. I am sure he has not had time to put it into a down loan state yet. Maybe talk him to see about a copy. Find a DAR who may help with a 337?.
30 Nov 2022 20:18 #3 by Super User
Replied by Super User on topic How to change GW from 1400 to 1450 on Forney F1?
You'd need to convert your F1 to an F1A, likely not possible (AFAIK), or find (or create) an STC for it.
  • Louis Kempfer
30 Nov 2022 20:16 #4 by Louis Kempfer
I have a Forney
 F1 #5714 that has a gross weight of 1400. the Forney F1A has a GW of 1450. What can I do to qualify for the 1450? Would help to stay legal with a passenger. Thanks!
