delco remy pull-starter
  • William James
22 Dec 2018 09:56 #1 by William James
Replied by William James on topic delco remy pull-starter
after several aggravating attempts to make "pull starter " work regularly, I converted to the push button start . . . like dying and going to heaven !!!
18 Dec 2018 06:33 #2 by Larry Snyder
Replied by Larry Snyder on topic delco remy pull-starter
The pull starter is easy to adjust. Just adjust the contractors. Getting a Sky-Tec is great but expensive and requires cutting off a shaft. I’ve been using my pull starter for 14 years with no problems.
  • Ken Thompson
07 Nov 2018 16:17 #3 by Ken Thompson
Replied by Ken Thompson on topic delco remy pull-starter
I second the Sky-Tech starter. Why spend the money to rebuild an out of date system? Convert and lose seven pounds in the process. Easier than going on a diet.
03 Nov 2018 21:32 - 03 Nov 2018 22:28 #4 by Gordie Meade
Replied by Gordie Meade on topic delco remy pull-starter
SkyTech lightweight starter. Uses a button push to start and all the pull cable stuff comes out. Saves about 7 pounds too.
Mine did that some too. Mechanic tapped the starter gently with a ball peen hammer to get the brushes to make contact. I removed the starter and cleaned the brushes, Worked OK after that. New starter worked much better. Spins the prop faster also.
Last edit: 03 Nov 2018 22:28 by Gordie Meade. Reason: typo
The following user(s) said Thank You: terrence o'neill
  • terrence o'neill
03 Nov 2018 15:38 #5 by terrence o'neill
Replied by terrence o'neill on topic delco remy pull-starter
Delco Remy starter... pull to start..... many pulls to get contact ... now no contact and no start....
How can this be made reliable?
Thanks,
Terrence
  • terrence o'neill
03 Nov 2018 15:34 #6 by terrence o'neill
delco remy pull-starter was created by terrence o'neill
Jjust bought plane. Starter worked for four flights,bugt had tp pull starter several times. Now pulls to engage, but no power to starter mptgor.
IHow can this be fixed, to start reliably each time?
Thanks.
Terrence
