Heat box/throttle linkage
06 Feb 2018 18:41 #1 by Larry Snyder
Replied by Larry Snyder on topic Heat box/throttle linkage
No airplane does that. I think a filter would slow the airflow and cool the air too much. When it comes to carb heat, you want the maximum amount of heat to melt carb ice.
  • Dean Weichmann
06 Feb 2018 17:43 #2 by Dean Weichmann
Replied by Dean Weichmann on topic Heat box/throttle linkage
Just musing here, why not filter air before the heater?
06 Feb 2018 17:36 #3 by Larry Snyder
There was a lever which would turn on carb heat when the throttle was closed. Most folks removed it because it had the unintended consequence of allowing unfiltered air into the carb when it needed filtering the most - while taxiing. Since the throttle is almost closed while taxiing, carb heat was automatically applied, meaning the air coming in was unfiltered.
  • Dean Weichmann
06 Feb 2018 17:03 #4 by Dean Weichmann
Heat box/throttle linkage was created by Dean Weichmann
My Ercoupe Instruction Manual (Univar) on page 6 says that when the throttle is fully closed air heat is automatically applied through a linkage connected to the throttle arm. My Coupe has no such linkage. Where can I find more info? Why would it be removed?
