- Questions from a newbie
20 Nov 2026 18:14 #1
Replied by John Jones on topic Questions from a newbie
John-
You might want to look through this archive which has answers to your questions web.archive.org/web/20180830182409/http:...om/Ercoupe/index.htm
Many folks prefer the "rag" wings, and as Ronald said, the new fabrics have much better longevity. If you have access to a hangar I wouldn't worry about that, and you would have a useful load gain with the fabric.
John
John
19 Nov 2026 15:08 - 19 Nov 2026 15:11 #2
Replied by Ronald Raty on topic Questions from a newbie
1. With a few modifications (including restricting elevator travel which restricts AOA which makes it difficult to stall), any Ercoupe can be converted to a 415D with a max load of 1400#. The mods are listed in the type certificate A718. Since the 415D is now light sport eligible, there isn't a lot of incentive to keep the lower gross weight limit.
2. Many years ago, rag wings would last about 10 years making metal wings attractive and worth the weight gain. Modern fabric systems last a lot longer.
3. Find an A&P that knows Ercoupes and particularly the AD's, many of which deal with corrosion. Corrosion is usually the deal breaker for an Ercoupe.
Last edit: 19 Nov 2026 15:11 by Ronald Raty.
- Warford Johnson
19 Nov 2026 14:25 #3
by Warford Johnson
Questions from a newbie was created by Warford Johnson
Hello Folks, I'm a new member, seriously considering buying an Ercoupe. The one I'm looking at is apparently a 415 CD with fabric wings, so I need some expert advice:
1) Why does the CD have max gross of 1280, while the C is 1400? Is that due to unrestricted elevator travel somehow, or is there another reason?
2) I recall hearing many years ago that one should avoid the "rag wings" in favor of aluminum. If that's true, why?
3) What unique issues should I be especially aware of for a pre-purchase inspection on this aircraft?
Any thoughts will be greatly appreciated!
John Johnson
John Johnson
