Remove big plug from carb
06 Jul 2022 09:19 #1 by Ron Holmes
Replied by Ron Holmes on topic Remove big plug from carb
I didn't take any pictures of the screen but it was pretty clean...I sent a couple of pictures from inside the carb and the needle.  I am trying to stop the carb from dripping when the fuel is turned on and the engine is not running. It is really a simple carb.  My mixture control was wired shut and I am going to try to remedy the no mixture as well.  There's a lot of safety wire on that thing.
  • Robert James
05 Jul 2022 21:13 #2 by Robert James
Replied by Robert James on topic Remove big plug from carb
I’d be curious to know if you found anything in the screen behind the big plug? Cheers,
27 Jun 2022 12:37 #3 by Randy Branson
Replied by Randy Branson on topic Remove big plug from carb
Ah so. Thanks!
26 Jun 2022 16:17 #4 by Ron Holmes
To check or clean the screen behind it...
26 Jun 2022 13:38 #5 by Randy Branson
I plead ignorance. Why did you need to remove the plug?
24 Jun 2022 19:30 #6 by Ron Holmes
Got it off... better socket and a little PB Blaster and a better choice of tools... Bingo easy....
Time to create page: 0.076 seconds
