- Alon brake system
Alon brake system
- Jack Lawless
11 Feb 2020 18:42 - 12 Feb 2020 16:05 #1
by Jack Lawless
Replied by Jack Lawless on topic Alon brake system
I will try to take a picture of it and post it here. As to how it worked out, when you pull the handle it's like you just hit the three wire.
Ok Here are brake pics
Last edit: 12 Feb 2020 16:05 by Jack Lawless.
- Kevin Whitcomb
10 Feb 2020 22:36 #2
by Kevin Whitcomb
Replied by Kevin Whitcomb on topic Alon brake system
So how did it work out? Love to see some pics of the install
- Jack Lawless
04 Oct 2017 00:27 #3
by Jack Lawless
Ed, that would be it. Same position as a Johnson bar. I think they first were offered on the Forneys. It has a white square button on the end you use to set as a parking brake. I flew one set up like this back in 1962 when I got my private. As I remember they work very well. Any pointers you have on them would be appreciated. By the way, I got the paperwork on this setup from Univair.
03 Oct 2017 23:11 #4
Replied by Edward Moore on topic Alon brake system
Jack, I think that's the system installed in my 415C - some paper work missing. Does yours have the integral parking brake incorporated and are you familiar with the operating procedure? If not, I can give it succinctly - I'm a slow key puncher so won't do it now. Think you will like the system - just like the old "Johnson Bar" flap handles in the early 172s.
Edd
Edd
- Jack Lawless
01 Oct 2017 14:23 #5
by Jack Lawless
The 337 mounts under the instrument panel between the panel and the header tank it appears. The factory handbrake I am using mounts to the main spare frame just ahead of the trim. It is convenient. You pull up on it similar to an auto hand brake. The holes for mounting the brake control were already pre-drilled by the factory. So no modification is necessary, just bolt it in place and hook up the brake hose. I have the parts out being powder coated to match the rest of the interior.
01 Oct 2017 12:50 #6
Replied by Warren Hampton on topic Alon brake system
How does it compare to the 337's drawing? found here in list.
